SpikeTheLobster Posted February 24, 2012 Share Posted February 24, 2012 I'm right in the middle of having a site developed in Drupal and I've been doing all my process diagrams in Excel for the moment. Hey, they look pretty good, so there! Some of them, however, have become... a touch unwieldy, shall we say. Here's a bit of a zoomed-out screenie of one of the longer ones, before I made it even more complicated: clickety-click. So I wondered... do any of you folks know of a really simple app that'll do this? I DON'T want something like FreeMind or other complicated, annoying, click-seven-times-to-do-anything apps (that's why I drew everything in Excel: it's simple) but if there's a drag-and-drop utility that'll do it, it might save me some hassle. Thanks guys...! Quote Link to comment Share on other sites More sharing options...
bloggeroo Posted February 29, 2012 Share Posted February 29, 2012 What kind of diagrams are you making? UML diagrams? May I recommend yEd from yworks.com? yEd is a Java-based application which you can install to run in your computer or run it online. I'm planning to standardize my design and development process around this tool. SpikeTheLobster 1 Quote Link to comment Share on other sites More sharing options...
bryce12 Posted February 29, 2012 Share Posted February 29, 2012 This may sound crazy but I have used MS Word and Excel several times to create flowcharts. This may not be the best option especially if you are working on a huge project but for smaller ones, it works like charm. Quote Link to comment Share on other sites More sharing options...
SpikeTheLobster Posted February 29, 2012 Author Share Posted February 29, 2012 I'd been doing mine in Excel, Bryce - like you, I found it easy, clear and workable. I just wondered if there was a simple alternative for some of the larger, more complex ones (since it can be a total cow if you miss a single step and have to move everything around). I'll take a look at yED, thanks Bloggeroo - it looks like the sort of thing I want. I'm not really doing flowcharts or UML or anything specific: more a mix of several formats that just shows the essentials so that Mr. Developer has some idea of what I'm talking about! Quote Link to comment Share on other sites More sharing options...
__Darknite Posted May 21, 2012 Share Posted May 21, 2012 The best method is GraphViz, it has its own language called "Dot Language". I've used this extensively, its very powerful. You could even automate things, example: if you have a database you can write a script to parse the schema and spit out a Dot Script. Quote Link to comment Share on other sites More sharing options...
SpikeTheLobster Posted May 28, 2012 Author Share Posted May 28, 2012 The best method is GraphViz, it has its own language called "Dot Language". I've used this extensively, its very powerful. You could even automate things, example: if you have a database you can write a script to parse the schema and spit out a Dot Script. Thanks, but I specifically don't want something powerful, with its own scripting language and everything. I want something I can throw diagrams together in, without too much effort and prep - yED seems the best match for what I need. The developer doesn't need minutiae (apparently I'm waaaaaay ahead of 99% of his clients, even with the ones I've done in Excel) so I don't need to worry about producing very detailed, complex things - just the basics. Nice to know there's a full-on app around, though. I'll keep a note of that in case I ever need it. Quote Link to comment Share on other sites More sharing options...
__Darknite Posted May 28, 2012 Share Posted May 28, 2012 The other option is DIA, its free and open source. Its very similar to microsoft visio. Quote Link to comment Share on other sites More sharing options...
