Henrawr Posted November 25, 2010 Posted November 25, 2010 I'm not sure why I did this, but I was fiddling with the QRCode app and made the following code to link to this site. So, if you plan on advertising, this is a pretty cool way to do so. <img src="http://cubeupload.com/files/8148971290729039.png"> Quote
Henrawr Posted November 26, 2010 Author Posted November 26, 2010 Why, yes, young man. If you take a picture of this code, or codes similar to this with a barcode/scanner app such as QRCode, then you can decode the image and be redirected to a website or application installation page etc. It can be pretty nifty. Quote
Henrawr Posted November 27, 2010 Author Posted November 27, 2010 With a free app called 'QRCode'. Just search for it on the android market. It's really easy to use, too. Quote
