<blockquote class='ipsBlockquote'data-author="johnthomas1433" data-cid="19599" data-time="1358230268"><p>
Rather than installing the PHP yourselves, I suggest you install some IDE like Xampp, or Wamp, and they does make your job easier. Also do not try coding in Dreamweaver, as they shall generate the code most of the times with drag and drop, and that is not good. Better use Notepad++ like the rest of us.</p></blockquote>
Please, make sure you understand the diference between a development environement ( Which is wamp, mamp, xampp... ) and an IDE which means interface development environement ( Which allow you to easily edit code files wih auto complete and color syntax )
  • 1 year later...
