What laptops would you recommend for me to get?
I don't want to spend much as I'm only going to be using it for doing college work and socialising with friends.
Here's a great laptop, the Toshiba Satellite T130-13Q. Might be slightly over your budget, however. It's around £350.
Specification:
Features:-
- Intel Pentium processor SU2700 / 1.3GHz, 800MHz, 1MB Cache
- Genuine Windows 7 Home Premium
- 3GB DDR3 Memory
- 320GB Hard Drive
- 13.3 Toshiba TruBrite HD TFT High Brightness with LED backlight and 16: 9 aspect ratio (1366x768 Resolution)
- Mobile Intel GMA 4500M integrated graphics using up to 1759MB of system memory
- Webcam
- Wireless enabled (WLAN 802.11b/g/Draft-N)
- Wired Network connection (LAN 10BASE-T/100BASE-TX)
- HDMI port for easy one cable connection to HD TV’s
- VGA port for external display
- 3 USB 2.0 ports
- Digital media card reader
- Up to 9 hours battery life
- Weight 1.76 kg
- Black Gloss with matt pale grey keyboard
- 12 Months Warranty
