Graphics Card.
Richio
Yes it would play Dirt 2, but it would be extremely limited gameplay, i.e. you would have to play on the lowest settings at a fairly low resolution. Codemasters recommends at least an nvidia 8800GTS or an ATI 46xx series card. If your looking at a card like that then the rest of your system must be pretty low-end meaning that the game might not run any way, I believe you have to have at least a 2.8GHz dual core processor (minimum). But if your looking for a new card for dirt 2 then you want to be looking at something a little higher up than that card, for example you can get a Radeon HD 5850 for around £150 or an Nvidia GTX460 for around the same price range, they will play the game on high settings no problem.
  • 2 weeks later...
  • 2 weeks later...
