Odie Hunt Posted January 26, 2011 Share Posted January 26, 2011 Can i get someone to email a detailed method of all the correct methods in getting my pc (HP notebook G61 Ser#CNF0133DFJ Product#WA965UA#ABC) to install drivers properly or call? i have been dealing with "uneducated HP and Microsoft personel all day and last night i just want to get this done and fixed i promise I'll be yer #1 fan! Quote Link to comment Share on other sites More sharing options...
Scotteh Posted January 26, 2011 Share Posted January 26, 2011 Hi there Odie, and welcome to Geeksoup.net! I'm afraid I'm slightly unsure of how to overcome this problem for you but I'm confident one of our members will be able to help you out. Just need to wait for them to come online and be active. Thanks for posting the problem. Quote Link to comment Share on other sites More sharing options...
DynamiteDai Posted January 26, 2011 Share Posted January 26, 2011 What operating system you running? Edit* was half asleep and didnt notice Quote Link to comment Share on other sites More sharing options...
Thrill Posted January 26, 2011 Share Posted January 26, 2011 What operating system you running? Windows 7. Can you not get into Safe Mode at all Odie? Quote Link to comment Share on other sites More sharing options...
Shaunno Posted January 26, 2011 Share Posted January 26, 2011 Hi I dont know whether you have tried this but I found a link on the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3873837&taskId=135 Could you see if any of the products on there seem familar and whether you can find the drivers. Do you know what drivers are missing? Goto the control pannel, then type in the search box device manager, then clcik on the device manager, when it opens check if any of the hardware has yellow cautions symbols next to it. Also you could check your disk drive for file errors, goto my computer, then right-click on the main drive (C usually), in the menu select properties then the tools tab click error checking, select both tick boxes and then start it will ask you to restart because it cant do it while the OS is using the drive, so clcik schedule a disk check and reboot. (http://www.w7forums.com/use-chkdsk-check-disk-t448.html) This site shows you how to schedule a disk check with images so it might be easier. GL and report back on your findings. Quote Link to comment Share on other sites More sharing options...
