no sound
malk
  • 7 years later...
I had similar problem like you. I solved it by moving a speaker's cable a little bit on the back of my computer and it somehow worked. You should try to plug them out and in a few times. If that does not work, try to install newest drivers or maybe even reinstall those drivers that you have right now and then install the new ones. If that does not work, you should maybe consider reinstalling your operative system. I hope some of these tips will help you. Good luck!
Possible problems
1) Computer speakers volume is low
2) Drivers are not installed
3) Drivers are not updated
4) Hardware problems in the wiring
Solutions:
1) Restarting your system
2)Sound test available in the system
3) Plugging out and plugging in the speakers
4) Increasing speaker volume
5) Trying the speakers on the laptop
There are many things to consider, maybe drivers are not installed, or you have a faulty jack, the solution would be to solve each possible problems one by one but if you can't really fix it then it's probably time to invest some money to it by hiring a computer technician.
