hardfix Posted April 29, 2011 Share Posted April 29, 2011 Dell XPS Model No: PP25L will not turn on. Charger works, but no power indicated when pushing the battery check button on bottom (with or without charger). No indication why... used it one night, next morning nothing. :'( Quote Link to comment Share on other sites More sharing options...
Shaunno Posted April 29, 2011 Share Posted April 29, 2011 Possibly the battery has failed completely, im not an electricion but if you have a multi meter you could use it to see if there is any output voltages from the pack. Quote Link to comment Share on other sites More sharing options...
hardfix Posted April 29, 2011 Author Share Posted April 29, 2011 Ok... Good. I do what might be a "snap out" door for a battery but maybe not. Any suggestions which screws I should loosen on the back? Quote Link to comment Share on other sites More sharing options...
CHiLL Posted April 29, 2011 Share Posted April 29, 2011 Remove the battery from the laptop, and plug the laptop into the mains. Does the laptop come on? If not, then that would eliminate the battery as being the cause of the fault. Quote Link to comment Share on other sites More sharing options...
hardfix Posted April 29, 2011 Author Share Posted April 29, 2011 I have not figured out how to remove the battery. One door is the harddrive. One looks like the memory chips. There is a large panel in the middle so that is all that is left. Is this the likely door? And, by mains you must mean the A/C with the battery out? Quote Link to comment Share on other sites More sharing options...
CHiLL Posted April 29, 2011 Share Posted April 29, 2011 There might be something along the lines of: It is a switch, slide it and pull the battery. Quote Link to comment Share on other sites More sharing options...
hardfix Posted April 29, 2011 Author Share Posted April 29, 2011 Excellent. That worked. I took the battery out and plugged in the charger. No power. I put the battery back in because the battery housing is a large integration piece of the laptop. Maybe it was no engaged completely. So, I have it on the charger to see if anything occurs in the next hour or so. I not power arrives, next... what to do? I did not VU meter the battery yet. Do not have the meter here yet. Quote Link to comment Share on other sites More sharing options...
CHiLL Posted April 30, 2011 Share Posted April 30, 2011 Well, in my opinion, you either have a faulty power adapter, or a faulty power connection on the motherboard. Failing that, the motherboard has given up the ghost. I don't know any cost effective ways to troubleshoot anything more than this. I'm sorry. Quote Link to comment Share on other sites More sharing options...
hardfix Posted April 30, 2011 Author Share Posted April 30, 2011 Got it. Not much more to say. I will take it to a shop and run some tests and report back as to diagnosis. This way closing the post will have a finish. Standby. Quote Link to comment Share on other sites More sharing options...
CHiLL Posted April 30, 2011 Share Posted April 30, 2011 Well, I do hope you get it fixed. Quote Link to comment Share on other sites More sharing options...
hardfix Posted April 30, 2011 Author Share Posted April 30, 2011 me too! Thanks 2. Quote Link to comment Share on other sites More sharing options...
Shaunno Posted April 30, 2011 Share Posted April 30, 2011 Hope you can get it fixed mate, sorry we couldnt be more of an assistance. Quote Link to comment Share on other sites More sharing options...
hardfix Posted April 30, 2011 Author Share Posted April 30, 2011 Y'all did great. Sometimes it goes beyond our reach, but only for a moment. After all, it may be really, really broken... like the mother board. If this is the case, the next challenge is to lift my stuff off the hard drive. I have six hard drives I need stuff off stretching over the last of 8 years ago... old archives and files I still would like to keep. So this is the next thing I will need geeksoup direction with. I would have to open this on another board, but first, I am taking the Dell to a shop... then we will see to the next. I know how to fix a lot of stuff, but geeksoup is where I turn when I do not. Hence, today. Quote Link to comment Share on other sites More sharing options...
CHiLL Posted April 30, 2011 Share Posted April 30, 2011 If you have access to a normal desktop computer, you could simply directly plug the hard drive from the laptop into the computer. 1) Ensure the computer is off, and remove side panel 2) Check if there are spare molex (power) or SATA power cables 3) Check if there are spare IDE or SATA cables available 4) Connect them to the laptop drive 5) Boot up computer and log on 6) Drive should appear in My Computer/Computer 7) Drag & drop or copy & paste information from laptop drive to elsewhere If 1), 2) or 3) cannot be met, then you need to look at using a different desktop, such as someone else's who is willing, or buy the necessary cables/converters. Quote Link to comment Share on other sites More sharing options...
