Emm:3 Posted May 2, 2011 Posted May 2, 2011 Didn't use my laptop for about half an hour, went back to it and it had froze. Turned it off and on again and it beeped 4 times. It froze again and after turning it back off and on again this time it was stuck on a white screen. Probably completely done for, but I thought I'd come here and see if anyone had any ideas what might be up with it. Laptop is a Dell Inspiron 1520 and it's Windows 7 if that's of any help. Quote
Emm:3 Posted May 2, 2011 Author Posted May 2, 2011 Yep, just 4 really quick high pitched beeps. D; Quote
Shaunno Posted May 2, 2011 Posted May 2, 2011 Four short beeps indicate a power related problem, however some people have reported this is a cache test failure (which could possibly be CPU related). I suggest you remove your RAm then reseat it (if thats possible) aloso remove any external devices. Reply back on your progress. Quote
Scotteh Posted May 2, 2011 Posted May 2, 2011 Four short beeps indicate a power related problem, however some people have reported this is a cache test failure (which could possibly be CPU related). I suggest you remove your RAm then reseat it (if thats possible) aloso remove any external devices. Reply back on your progress. I can tell you that this user isn't that advanced Shaun. Quote
Shaunno Posted May 2, 2011 Posted May 2, 2011 Four short beeps indicate a power related problem, however some people have reported this is a cache test failure (which could possibly be CPU related). I suggest you remove your RAm then reseat it (if thats possible) aloso remove any external devices. Reply back on your progress. I can tell you that this user isn't that advanced Shaun. Orite well in that case I gues the best thing to do would be to take it to a computer shop, preferably not PC world cos they charge a bomb. Quote
Emm:3 Posted May 3, 2011 Author Posted May 3, 2011 Four short beeps indicate a power related problem, however some people have reported this is a cache test failure (which could possibly be CPU related). I suggest you remove your RAm then reseat it (if thats possible) aloso remove any external devices. Reply back on your progress. I can tell you that this user isn't that advanced Shaun. Orite well in that case I gues the best thing to do would be to take it to a computer shop, preferably not PC world cos they charge a bomb. Definitely not advanced at all. Thank-you though, had issues with PC World before so I'll certainly avoid there. :') Quote
Scotteh Posted May 3, 2011 Posted May 3, 2011 Four short beeps indicate a power related problem, however some people have reported this is a cache test failure (which could possibly be CPU related). I suggest you remove your RAm then reseat it (if thats possible) aloso remove any external devices. Reply back on your progress. I can tell you that this user isn't that advanced Shaun. Orite well in that case I gues the best thing to do would be to take it to a computer shop, preferably not PC world cos they charge a bomb. Definitely not advanced at all. Thank-you though, had issues with PC World before so I'll certainly avoid there. :') It's definitely a hardware error, you'll need to have good technical knowledge with computers specifically laptops to resolve it, so I'd take it to a shop or get me, seeing as you know me IRL to fix it for free. :') Quote
