Scotteh Posted July 16, 2011 Posted July 16, 2011 Still happening, crashing during playing intense games. I see a lot of people are having the same problem: http://forums.nvidia.com/index.php?showtopic=202255 My temperature is fine, all my components are sufficient for playing the games but still crashing. Will nvidia ever fix this? D: Quote
Thrill Posted July 16, 2011 Posted July 16, 2011 ATI all the way? Never had that on any of my old NVIDIA cards, not owned any after 2008 though Quote
Scotteh Posted July 16, 2011 Author Posted July 16, 2011 This is exactly what I'm experiencing: http://forums.nvidia.com/index.php?showtopic=202580 I don't wanna trade my £200+ GFX card for an ATI. EDIT: Gunna try the possible fix, I'll report back. Quote
Scotteh Posted July 20, 2011 Author Posted July 20, 2011 Reverted back to the drivers on the CD after uninstalling them, did a clean installation and still no joy so I went back to the latest ones... This is really frustrating... Quote
Shaunno Posted July 20, 2011 Posted July 20, 2011 Have you patched the games to the latest version? Quote
Scotteh Posted July 21, 2011 Author Posted July 21, 2011 Have you patched the games to the latest version? Yeah mate. Quote
Scotteh Posted July 21, 2011 Author Posted July 21, 2011 Using GPU-Z do these look normal to you guys? This is after playing GRID for 10 mins before the screen went black and crashed to desktop. Stats: Before: After: Quote
Shaunno Posted July 21, 2011 Posted July 21, 2011 Well the temps are fine. All looks normal mate. Edit: One thing you could try is backing the frequencies down a little, cos the other 560 Ti's i've seen have their core clock at 850Mhz, which in turn reduces the shader clock as they are linked. You can use MSI Afterburner and just tune em down a bit. If you find it works you can make different profiles on Afterburner and run at full speed on the games that don't crash and clocked down a little on the games that do crash, just a suggestion. Download link http://event.msi.com/vga/afterburner/download.htm Quote
Scotteh Posted July 21, 2011 Author Posted July 21, 2011 I've heard some people have fixed the problem doing that, cheers mate I'll give it a shot. Quote
Thrill Posted July 22, 2011 Posted July 22, 2011 Temperatures look fine mate. Shaun's given some great advice, you should take it Quote
Scotteh Posted July 22, 2011 Author Posted July 22, 2011 I did it and it totally messed up the game graphics. :l Weird thing is this happens when I run some games on the highest possible settings, but when I run them on medium they were fine for ages so. D: Quote
Shaunno Posted July 22, 2011 Posted July 22, 2011 You've over clocked your cpu right? Test its stability with prime95. Download link: http://www.softpedia.com/progDownload/Prime95-Download-76537.html You can also test the stability of your GPU with furmark. Download link: http://www.ozone3d.net/benchmarks/fur/ Quote
Scotteh Posted July 23, 2011 Author Posted July 23, 2011 I haven't overclocked yet no. ): But I'll test the stability of the GPU. EDIT: Pretty fun the GPU thing haha, ran it on the 1080 preset and got these results: I ran it with full anti-aliasing and did the burn-in test with dynamic camera and had very low FPS, like ranged between 8 and 15. Quote
Shaunno Posted July 23, 2011 Posted July 23, 2011 Ye thats quite bad lol i get around 65fps, but did it crash at all or reset? Quote
Scotteh Posted July 24, 2011 Author Posted July 24, 2011 With full AA and 1080p? No it didn't. D: Quote
Shaunno Posted July 24, 2011 Posted July 24, 2011 Edit: the old furmark i got 65 fps, this new version is different and ye get 37fps average on the 1080p preset benchmark, btw you didnt have AA on, as you can see in the SS 3rd box down AA:0 samples, if you put AA to MSAA 8x yo uwill see your fps drop low mine was around 18 average with full AA 1080p. I really dont know what to suggest if it didnt crash then theres nothing wrong with any of your hardware, its probably a driver compatibility issue. If i come across any other fixes ill be sure to post em on here. Quote
