Sound hardware lies undetected !!
MAJESTIC
If you go to the device manager do you see devices with yellow exclamation marks or question marks, also check under the sound tab in the device manager and check it hasnt being disabled. Also did the problem come on suddenly or have you reinstalled windows?
@Thrill  mine is da Mora motherboard, 945Ghz Micro 775 SE loaded wid windows xp, service pack 2 version 2002.
@Shaunno i havnt re-installed my windows nor am i getting ny yellow exclamation marks in device manager section.
First, download the sound driver from here; http://download.biostar.com.tw/upload/Driver/Audio/Realtek/HD/2KXP/WDM_R257.exe.
Now, in Device Manager, browse to "Sound, video and game controllers". Find your sound card, right click it, and select Uninstall. Reboot your computer. Run the setup file you downloaded from the link above, go through the setup and then reboot once complete. Does your sound now work?
This topic is now closed to further replies.
