Jessi Posted March 15, 2012 Share Posted March 15, 2012 http://dirtymarkup.com/ Has anybody used this site or know anything about it? Supposedly you just copy/paste your current code and it'll tidy things up for you. Because it doesn't show me the changes it made, though, I'm hesitant to use the outputted results. I would rather something that points out any errors or useless extra code instead, I think. Any suggestions of something similar, maybe, that doesn't sound sketchy at all? I'm sure this site as fine and came from a reputable source, but I'm still skeptical. Quote Link to comment Share on other sites More sharing options...
Administrators Nathan Posted March 16, 2012 Administrators Share Posted March 16, 2012 Hmm...I'm not sure it's working correctly, I tried putting some bad HTML in there on purpose. When I hit to clean it just erased my code and gave me a basic page layout for HTML. Quote Link to comment Share on other sites More sharing options...
Administrators Tony Posted March 16, 2012 Administrators Share Posted March 16, 2012 Looks like it worked fine for me Quote Link to comment Share on other sites More sharing options...
Jessi Posted March 16, 2012 Author Share Posted March 16, 2012 Hmm...I'm not sure it's working correctly, I tried putting some bad HTML in there on purpose. When I hit to clean it just erased my code and gave me a basic page layout for HTML. Hmm. Well technically, I suppose if it removed the bad code, then that worked correctly, right? To simply clear it instead of fixing it doesn't sound very helpful, though. And Tony, what did it do for you? Quote Link to comment Share on other sites More sharing options...
