nightjade Posted April 27, 2012 Share Posted April 27, 2012 Basic SEO practices for newbies: The thing to remember is that SEO isn't a magic bullet. It's important, but no one knows the exact algorithms the SEs use, and each one is different so all you can do is optimize the best you can. There happens to be a few things that you should just always do whenever you make a new website. Don't stress over every little thing, just make sure you are doing it, this should just become kind of automatic for you. Make sure you fill in your meta tags with a good title, description, and the right keywords. I personally don't think the keywords meta-tag is nearly as important as everyone else on here does, but it gives me a way to organize my keywords list for me to reference. When you start having many different websites, it's good to include whatever notes to yourself you can. When you come back to work on an older site you might not remember eveything you were thinking before. The metatags help you remember your site info as much as it helps the SE figure it out. A good rule of thumb is that anything that won't hurt you for SEO and might help, you should use and use correctly. Definately use the title meta-tag, try to include keywords in the title. Definately use the description meta-tag, google will normally use this for the summary it displays in the listing. It isn't used for indexing so write it for humans, this is what gets people to click on your link when they see it in the SERP. Don't use the same metatags for every page on your site. Take the time to make them be specific to each page. Create good content. Make sure you have some decent content. Content is what the internet was invented for. If you have unique and quality content, then all the seo and backlinking you're doing is just to get the ball rolling. Give them what they want, show them where it is, and they'll start coming. If it's good enough then it'll eventually start building on its own naturally because people like what they found. That's the idea anyway. So whenever possible use the best page design and the best content possible. Avoid duplicate content between different pages on your site, the SE will most likely penalize your site for that. Remember, your content isn't just something to get google to like your site, it is the whole point of your site. The content and how you structure it is what will make visitors do what you want when they get there. If it's crap they'll just leave, and 99% of them won't leave by clicking on your adsense or affilliate link, they'll just close the window or use the back button. (yes, of course if your doing blackhat stuff you can make the browser go where you want, but that's for a different discussion.) Include your keywords. Structure your content correctly, make a few title headers in the content that include keywords (use header tags h1, h2, etc.), try to have a keyword density around 2% in your content, and maybe 4% for the whole page including the metatags, alt tags, anchors, etc. Be sure that your .htaccess is set up correctly. Decide on which way you want your url to be and stick with it. If you decide to use www then always use it like that in your links, don't use both. I usually set up a 301 for all www requests to redirect to non-www urls. If you don't set that up then every single page on your site can appear to google as having at least one duplicate. If that's the only thing wrong on your site it isn't going to kill you, but it's so easy to fix. If you don't know how to set up a redirect in your .htaccess file then just do a search, there are many other threads explaining it. Check google if you can't find it here. Also, .htaccess only apples if your on an Apache server, Windows servers do it a little differently, if that applies to you then just search google to find out how to do it. If your consitent in your linking, then the only time the redirect will come into play is if you get natural backlinks that you have no control over. You should also specify which you prefer, www or not-www in google tools if you use it. (If you don't then you really should, I recommend you set yourself up an account for webmaster tools and analytics.) Make a robots.txt file and I like to include a favicon because without them the robots will trigger file not found errors on your server. Be sure to configure your robots.txt correctly. Make a custom 404 page. If your site has more than just a couple of pages then also create a sitemap.xml file. It's not a bad idea to just create a sitemap anyway no matter what, it lets you define the structure of your site to the crawlers. Just search google if you don't know how to do any of that, it's very basic and you can find exact instructions within a minute when you do a search. Other than that there isn't a lot more you can do for on-site SEO. When people ask about SEO they're always thinking of on-site SEO, but thats the easy and quick part. Just do it and get on with it. Everything else is off-site SEO and involves building backlinks and promotion. This is where you need to focus your efforts. This is where the magic bullet is, if there really is one. Social Bookmarks, Directory Submissions, Profile Links, and Blog Comments are really the easiest place to start getting backlinks. It's not a bad idea to purchase these links from a service. They are easy to make, but to do it right they really need to be posted from many different accounts and ip adresses. A good idea when your starting is to do it yourself a little bit to see how it works, then purchase larger quantities from a service. You want to get a lot of links, but you don't want to over do it. Building to fast can look unnatural, just do some searches and read up on it a little more. How many and how fast is a judgement call you have to make. hold off on more complex linkbuilding until you have a little more experience. Linkwheels and other link structures can be very powerful, but can also hurt your site a lot if not done correctly. Whenever possible include keyword anchors and title or alt tags on your backlinks. Don't always use the same anchors, vary it up a little, use 3 or 4 different keywords and even do a few with some non keyword anchors. You are trying to look as though a lot of different real people have taken a liking to your site, if it were natural then all links wouldn't be exactly the same, so you want to simulate that same type of randomness. Backlinking strategies are all about simulating the natural events that happen as a site grows in popularity. If you can do it successfully then the SE's will give you good position in the listings, and then hopefully what you are simulating can become reality. The point of all of it is to get traffic. Change up your anchor text. The idea of backlinking is to simulate that masses of people are becoming interested in your site. It should have some amount of randomness to it in order to look natural. I've seen a few made up stats on what's best, but I think a good rule of thumb is maybe about 45% primary keywords, 35% secondary keywords, and about 15% random unrelated like Click Here, and then about 5% just the url. The exact percentage isn't dramatically important, it just needs to seem like the linking is natural. Create relevant articles containing your keywords, include backlinks using keyword anchors, and submit to article directories. Article directories are mostly authority sites and your article becomes a relevant backlink to your site. Then create profiles and accounts on blogs, social networking sites, forums etc. Include a link to your website whenever you do that and each one of those become backlinks as well. Thats the end of it. Well kinda. Go back and watch your stats to see what keywords are getting the most traffic to your site, analyze the data a little bit and if you need to, remove or add keywords to your content and tags, and adjust the anchors your using in your backlinks. Continue building links. Remember you're trying to artificially create the appearance to the SE that your site is popular. When that happens naturally, people are always adding new links to your site. Since you are trying to look natural you have to do the same thing. Linkbuilding never stops completely. OK, there you go. That's that basics of SEO. Everything else is about fine tuning, and has to be looked at for each individual situation. If you have any more questions, before you start PMing anyone just read through the threads in the White Hat SEO section, and do some searching on google. You can find some really good information from some much smarter people than me. If there are any SEO gurus that want to expand on this or if you see any errors you think should be discussed, please add your input. Hope this can help some of you. Quote Link to comment Share on other sites More sharing options...
SpikeTheLobster Posted April 28, 2012 Share Posted April 28, 2012 Nice. Some good info there. A few notes from Mr. Editor which should improve the content for the next time you post it somewhere: I personally don't think the keywords meta-tag is nearly as important as everyone else on here does I don't think anyone on here thinks it's very important. Definately use the title meta-tag, try to include keywords in the title. The title tag isn't meta. If it was, it'd have "meta" in the tag. Don't use the same metatags for every page on your site. Take the time to make them be specific to each page. I assume you mean each static page. We all assume that but newbies will sit there wondering how they change the meta on all the different pages of their gallery or every individual blog post and so on. (And I don't think you want to confuse them with that.) Create good content. [...] So whenever possible use the best page design and the best content possible. Confusing to suddenly have a reference to "best page design" when you're talking about content. Newbies will worry that they've missed something when you haven't actually talked about it. (yes, of course if your doing blackhat stuff you can make the browser go where you want, but that's for a different discussion.) Not needed, since you're writing for newbies. Include your keywords. Structure your content correctly, make a few title headers in the content that include keywords (use header tags h1, h2, etc.), try to have a keyword density around 2% in your content, and maybe 4% for the whole page including the metatags, alt tags, anchors, etc. A lot of assumptions in that paragraph: you assume that newbies know what keywords are, how to structure content correctly, that they'll understand the difference between "title headers" here and "title tag" above, that they know what keyword density is and what alt tags and anchors are. Be sure that your .htaccess is set up correctly. Decide on which way you want your url to be and stick with it. If you decide to use www then always use it like that in your links, don't use both. I usually set up a 301 for all www requests to redirect to non-www urls. This entire section is way beyond newbie SEO. Most newbies are using a CMS and don't even know how to FTP to their hosting account. I'd save that section - and the part about robots.txt, sitemaps and so on - for a separate article entirely. Everything else is off-site SEO and involves building backlinks and promotion.This is where you need to focus your efforts. This is where the magic bullet is, if there really is one. Your opening statement, pretty much, is that SEO is not a magic bullet. Although you're not strictly contradicting yourself here, you'd be better off with just "This is where you need to focus your efforts." Social Bookmarks, Directory Submissions, Profile Links, and Blog Comments are really the easiest place to start getting backlinks. It's not a bad idea to purchase these links from a service. They are easy to make, but to do it right they really need to be posted from many different accounts and ip adresses. You assume they know what backlinks are: many newbs don't. You also say - again - to go and read up on it: that's what they're reading your article for. This is basic stuff (unlike server .htaccess and so on) so you should really cover it. You don't need to go into great detail but you do need to explain what it is and how it works for the average site owner (i.e. doing it yourself). Then you can advise that there are services to do this for you and warn against doing too much too quickly (with proper reasons rather than "it can harm your site"). Whenever possible include keyword anchors and title or alt tags on your backlinks. Don't always use the same anchors, vary it up a little, use 3 or 4 different keywords and even do a few with some non keyword anchors. You are trying to look as though a lot of different real people have taken a liking to your site, if it were natural then all links wouldn't be exactly the same, so you want to simulate that same type of randomness. 90% of your audience won't understand that, especially since you didn't define the terms earlier. If you have any more questions, before you start PMing anyone just read through the threads in the White Hat SEO section, and do some searching on google. You can find some really good information from some much smarter people than me. There is no White Hat SEO section here. When you're copy/pasting content from other forums, it's always worth looking for references that will make it obvious. It's also better form to simply include an excerpt and point to the original. Note: I didn't correct spelling, grammar, etc. And I edited on the fly, so I probably missed some stuff. Hope it helps. Quote Link to comment Share on other sites More sharing options...
merlyn73 Posted May 22, 2012 Share Posted May 22, 2012 Your emphasis on quality content is dead on accurate, and it's where I have seen so many startup websites fail. Any doubt you may have about this could be settled with a single day trip through Google's Blogger and gaze at all the derelict blogs that were just posts of internet memes and YouTube videos. Quote Link to comment Share on other sites More sharing options...
psufootball Posted May 25, 2012 Share Posted May 25, 2012 An excellent post with an excellent theme- quality over quantity! I don't know a lot about SEO but I do understand the key points to keep in mind behind it and that is one of them. That and don't spam! I hate it when people think that by spamming it will get people not only interested, but appreciative of their content. It's not going to get you anywhere! Quote Link to comment Share on other sites More sharing options...
bryce12 Posted May 26, 2012 Share Posted May 26, 2012 Great post! I would argue about keyword density since Google Penguin has affected a lot of sites with high Keyword density. Nowadays experts are recommending not to have even 2% keyword density and not to put keyword in header tags multiple times. If you use a SEO plugin like Clickbump or EasyWPSEO, then don't follow all their recommendations otherwise your site could be hit by overoptimization penalty. Quote Link to comment Share on other sites More sharing options...
ljepilo Posted May 26, 2012 Share Posted May 26, 2012 Indeed this is a great post. I have been to SEO for 8 months now,hardly I can call myself a newbie in SEO,but this post contains really sufficient informations for those who are just starting with it ! Hoping to see more posts like this ! Quote Link to comment Share on other sites More sharing options...
tosaytheleast Posted May 29, 2012 Share Posted May 29, 2012 Wow! Impressive! Thank you so much for sharing what you now to us. I am newbie in SEO and I have read more or less articles similar to this but this probably might be on top of my list. It is well explained and very easy to understand. I am absorbing it for now and I would really glad to as some questions later, Quote Link to comment Share on other sites More sharing options...
ridwan sameer Posted May 29, 2012 Share Posted May 29, 2012 Excellent Post mate. Saved it, Will be using it when I start my site.. Hopefully. But this is more directed towards a coded site and not .. lets say.. A Forum. Not that that's a bad thing though... Quote Link to comment Share on other sites More sharing options...
