Administrators Nathan Posted May 4, 2012 Administrators Share Posted May 4, 2012 Sometimes if the database is not designed correctly you will find dates stored as text values. When trying to compare dates to text you will have problems and it's not efficient. So that's where the cast function comes in. Table: Invoice Field: InvoiceDate Data Set: 20080515 20081025 20070113 20091007 Expected Data Set: 05/15/2008 10/25/2008 01/13/2007 10/07/2009 To do this simply cast the field as a date: select cast(InvoiceDate as datetime) from Invoice Quote Link to comment Share on other sites More sharing options...
S.O. Price Posted June 6, 2012 Share Posted June 6, 2012 Sometimes if the database is not designed correctly you will find dates stored as text values. When trying to compare dates to text you will have problems and it's not efficient. So that's where the cast function comes in. Table: Invoice Field: InvoiceDate Data Set: 20080515 20081025 20070113 20091007 Expected Data Set: 05/15/2008 10/25/2008 01/13/2007 10/07/2009 To do this simply cast the field as a date: select cast(InvoiceDate as datetime) from Invoice Thanks for the tip, but I hope I never have to use it! That means I had to take over a database from someone who was probably a beginner. There will probably be more quirks like that elsewhere. On the other hand, sometimes one has to import a file of a different type and in this case 'cast' might come in handy for some fields that need to be converted to datetime.. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 6, 2012 Share Posted June 6, 2012 Another handy one to add to this is the removal of times from datetime. Now there are a few ways of doing this and I prefer not to use convert even though that is what it is made for. Reason? because I dont have to remember the format code Dataset 2011-04-06 10:56:00.000 Desired 2011-04-06 00:00:00.000 SELECT CAST(LEFT(InvoiceDate),11) AS DATETIME) FROM invoice If you are interested the other way of doing it is the following SELECT Cast(Convert(varchar, InvoiceDate,105) as datetime)FROM invoice[/sQl] Quote Link to comment Share on other sites More sharing options...
