So I'm having some problems here.
http://Digitize Design.net/pm/
Username: nathan
Password: test123
As you can see the project boxes fall under each other. I need them to go 3 accross then have a line break and continue that way for as many projects as there are. Any suggestions?
why not use divs?
<div class="project_wrapper">
    <div class="project">
    </div>
    </div>
    </div>
</div>
The projects class would be float:lefts with clear:none. The Project_Wrapper would be float:left with clear:both.
Hope that helps :)
I'm extremely new to CSS and HTML so trying to learn. I will give that a try, I thought I already have divs in there.
Posted (edited)
Your while loop's screwed in projects.php.
If you want them three across, you'll need to do something like a stepped FOR loop, taking them three at a time ("number of rows div 3" times) or a FOR inside a while (though it'll be weird) or a complex IF with a manual counter (which is a bit old-school but works and is sooooo easy to read).
Effectively something like this (which is only one way of doing it):
while the current display row number < total number of rows
if there is a row of 3 to show
show three from current display row number
increment current display row number by 3
elseif there are 2
show those 2
increment current display row number by 2 (or 3, whatever makes it bigger than the total so the loop ends)
elseif
show the one remaining
increment current display row number by 1 (or 2 or 3, whatever makes it bigger than the total so the loop ends)
end if
end loop
Or alternatively:
get number of rows returned MOD 3; (call it leftovers)
get number of rows returned DIV 3; (call it cycles)
FOR cycle times
show a line of three projects (at row numbers cycle*3, cycle*3+1, cycle*3+2 (assuming it starts at 0))
add a line break
END loop
FOR leftovers times
show one project and make sure there's no line break
END loop
Hope it helps. Note that it's not in PHP because I only taught myself the language in an hour on Tuesday and it's probably less confusing (for you!) for me to write in pseudocode than try to do real PHP. :D
Edited by SpikeTheLobster
