ridwan sameer Posted June 7, 2012 Posted June 7, 2012 (edited) Was just messing around in Photoshop, Thought I'd Create some Forum Rank Images. This was just one, Wanted to know your guys opinions before I created the rest of the set. If I complete this I'll release it as a free set, Obviously. Admin Edit : - Fixed the border.... A little Better now. Thinking of going for the Rounded edges approach Edited June 7, 2012 by ridwan sameer Marc and Nathan 2 Quote
Administrators Nathan Posted June 7, 2012 Administrators Posted June 7, 2012 Looks cool, I agree with the rounded edges. Quote
ridwan sameer Posted June 7, 2012 Author Posted June 7, 2012 Hmm... Ill Make a seperate Rounded edged one and post it here to get some opinions though. Quote
Marc Posted June 7, 2012 Posted June 7, 2012 Would also add a small amount of shadowing to the text. Quote
ridwan sameer Posted June 7, 2012 Author Posted June 7, 2012 I actually added the shadow before you mentioned it Here;s the updated one.. Nathan, I can't seem to edit my original Thread Quote
ridwan sameer Posted June 7, 2012 Author Posted June 7, 2012 I Dont like the font though. Might look for a "bit" font. Quote
Administrators Nathan Posted June 7, 2012 Administrators Posted June 7, 2012 I actually added the shadow before you mentioned it Here;s the updated one.. Nathan, I can't seem to edit my original Thread I think the limit to edit posts are 5-10 minutes. It's fine to post it below as you did. Quote
Jessi Posted June 7, 2012 Posted June 7, 2012 I actually added the shadow before you mentioned it Here;s the updated one.. Nathan, I can't seem to edit my original Thread I like this one much better than the first. The rounded corners aren't nearly as harsh. It seems like a little bit of the shadowing on the letters, though, might make it hard to read the word at a smaller size, but I don't see it being much of an issue. Quote
ridwan sameer Posted June 7, 2012 Author Posted June 7, 2012 I was trying to mess with teh shadows to make sort of an "Embedded" Look... I seem to have made more of a Popping out look. Quote
ridwan sameer Posted June 7, 2012 Author Posted June 7, 2012 I did use it, But i think i lowered the opacity too much to be seen. Ill have to adjust that a little. Quote
Marc Posted June 7, 2012 Posted June 7, 2012 I did use it, But i think i lowered the opacity too much to be seen.Ill have to adjust that a little. How about inner glow one side and shadow the other? Sent from my GT-I9100 using Tapatalk 2 Quote
ridwan sameer Posted June 7, 2012 Author Posted June 7, 2012 Wouldnt that have the same effect? No, I think I can make the Inner shadow work, I just need to adjust it a little Quote
Marc Posted June 7, 2012 Posted June 7, 2012 Wouldnt that have the same effect? No, I think I can make the Inner shadow work, I just need to adjust it a little No as it would highlight the inner of the otherside and give the effect of a deeper cut Quote
