Marc Posted June 8, 2012 Share Posted June 8, 2012 OK linux guys Im stuck. Decided today out of the blue that I was gonna run ubuntu for a month. Why? Because Im a bit of a nut job and though it would be a good idea LOL Anyways, I am having some problems with sound. I have an MAudio Delta Audiophile 2496, which is an excellent card right up to the point you want it on linux apparently. There are no drivers out there that I can find other than open sound which is here http://www.opensound.com/ .. Now these look quite old, and dont seem to work. Therefore I am currently stuck for sound. Any ideas? Thoughts? Quote Link to comment Share on other sites More sharing options...
Administrators Nathan Posted June 8, 2012 Administrators Share Posted June 8, 2012 Hmm...just reformatted a few weeks back after my drive failed and haven't installed this again yet. One sec Quote Link to comment Share on other sites More sharing options...
Marc Posted June 8, 2012 Author Share Posted June 8, 2012 Hmm...just reformatted a few weeks back after my drive failed and haven't installed this again yet. One sec You got the same card then? LOL Quote Link to comment Share on other sites More sharing options...
Administrators Nathan Posted June 8, 2012 Administrators Share Posted June 8, 2012 You got the same card then? LOL No I don't, but just reminded me to install it again. Going to give the drivers ago on my card as well. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 8, 2012 Author Share Posted June 8, 2012 No I don't, but just reminded me to install it again. Going to give the drivers ago on my card as well. LOL, glad it gave you the reminder Quote Link to comment Share on other sites More sharing options...
Administrators Nathan Posted June 8, 2012 Administrators Share Posted June 8, 2012 My sound worked out of the box, sorry for hijacking your thread, back to Marc's issue! Quote Link to comment Share on other sites More sharing options...
Marc Posted June 9, 2012 Author Share Posted June 9, 2012 My sound worked out of the box, sorry for hijacking your thread, back to Marc's issue! No worries. It serves me right for having a production soundcard I guess LOL. I will find an answer somehow Quote Link to comment Share on other sites More sharing options...
ridwan sameer Posted June 9, 2012 Share Posted June 9, 2012 Dont you have the installation CD? I remember formatting mycomputer, the sound was build in on the motherboard, so I had to use the Motherboard's CD To get the sound back. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 9, 2012 Author Share Posted June 9, 2012 Dont you have the installation CD? I remember formatting mycomputer, the sound was build in on the motherboard, so I had to use the Motherboard's CD To get the sound back. LOL if only it was as easy as a motherboard CD. The card I have is a studio production soundcard and they dont actually do drivers for linux at all. Therefore I am stuck looking for third party solutions. Now by the looks of it this has happened in the past, but not sure if I can do so anymore. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 16, 2012 Author Share Posted June 16, 2012 (edited) If anyone else has this problem with the same card, you need to do the following to get sound: Go to terminal and type the following alsamixer Press F6 once you are in the alsamixer and you will be able to change the sound card to audiophile 2496. Once you are in here you need to move across to the channels with the sound level bars and move them up to at least 80% Now exit this and type the following into terminal gksudo gedit /usr/share/alsa/cards/ICE1712.conf Once you have the config file open look for the "front" channel section and make it look like the following ICE1712.pcm.front.0 { @args [ CARD ] @args.CARD { type string } type route ttable.0.0 1 ttable.1.1 1 slave.pcm { type hw card $CARD } slave.format S32_LE slave.channels 10 Save this and exit terminal. All you have to do now is enter your sound settings by clickgin on the sound icon in your taskbar and clicking sound settings. Once in there select Analog Output. Thats it you should now have sound. If you dont try restarting. Edited June 16, 2012 by Marc Nathan 1 Quote Link to comment Share on other sites More sharing options...
Marc Posted June 28, 2012 Author Share Posted June 28, 2012 For anyone else doing this, do not make the edit to the conf file as it will cause a problem with upgrades. I had to revert my back and once the update to the soundcard was done it was fine after the following: Open Alsamixer as stated above. Turn up all the volumes as stated above. BEFORE closing ensure the end value is not set to mm otherwise your soundcard is totally muted at the driver. Quote Link to comment Share on other sites More sharing options...
