gaifboy Posted June 22, 2012 Share Posted June 22, 2012 I have been programming in javascript and jQuery for a while now but I haven't found a good editor for these languages. I have tried notepad++, netBeans, Visual Studio and Aptana Studio and so far netBeans has been the best pick. Java has multiple editors with great support, C# and VB.net has Visual Studio and it feels like javascript has been left without a good IDE. I want to have a editor which can autocomplete methods and with support for jQuery. Is there such a tool? What do you use? Quote Link to comment Share on other sites More sharing options...
ridwan sameer Posted June 23, 2012 Share Posted June 23, 2012 Sublime Text 2 Is my favorite all round editor Quote Link to comment Share on other sites More sharing options...
Marc Posted June 23, 2012 Share Posted June 23, 2012 Have you tried Visual Studio 2012? I realise its in RC at the moment, but one of the major improvements is javascript support due to its emphisis on building apps for windows 8 and metro Quote Link to comment Share on other sites More sharing options...
__Darknite Posted June 23, 2012 Share Posted June 23, 2012 (edited) I just use notepad++, it does actually have "custom auto-completion". However to be honest, its not the end of the world. In regards to jquery, as wonderful as it is. If you really want to leverage the power of JavaScript. Try doing it in raw JavaScript whenever possible. Edited June 23, 2012 by __Darknite Quote Link to comment Share on other sites More sharing options...
ridwan sameer Posted June 24, 2012 Share Posted June 24, 2012 I just use notepad++, it does actually have "custom auto-completion". However to be honest, its not the end of the world. In regards to jquery, as wonderful as it is. If you really want to leverage the power of JavaScript. Try doing it in raw JavaScript whenever possible. I much prefer the Library in JQuery though.. Powerful yet easy Quote Link to comment Share on other sites More sharing options...
bryce12 Posted June 30, 2012 Share Posted June 30, 2012 (edited) I mostly use Textpad or Notepad++ because I don't look for fancy features in editors. On the same subject, has anyone tried Yaldex? It looks like a decent Javascript editor which also happens to be free. Edited June 30, 2012 by bryce12 Quote Link to comment Share on other sites More sharing options...
JHTech100 Posted June 30, 2012 Share Posted June 30, 2012 (edited) The only editor I ever use is Eclipse with the Aptana Studio plugin. Nothing else at all. Edited June 30, 2012 by JHTech100 Quote Link to comment Share on other sites More sharing options...
devilishomar Posted December 22, 2013 Share Posted December 22, 2013 I have used multiple editors when I first started out and the first thing I looked for was simplicity and good design (for my eye candy standards). I tried Visual Studio, and though it had a good design, it wasn't simple. There's just so many buttons!I then tried Netbeans. Netbeans was okay, but when I heard about Eclipse and tried the latter, it turned out to be much better in terms of both design and simplicity. So I would suggest you give Eclipse a try. Quote Link to comment Share on other sites More sharing options...
Navii Posted July 17, 2014 Share Posted July 17, 2014 In my opinion sublime text 2 is the best, since it autocompletes most functions and it also has a dropdown list, that's really nice when you are not sure about a command. I also like that you can change the theme of it easily, because my eyes start to hurt when I look at a bright screen for too long. That's why I use one of the darker themes. Quote Link to comment Share on other sites More sharing options...
Administrators Nathan Posted July 17, 2014 Administrators Share Posted July 17, 2014 I don't user any but PHP Storm since I found it about 2 years ago. Quote Link to comment Share on other sites More sharing options...
johnv5 Posted January 4, 2019 Share Posted January 4, 2019 Here, Some In-Demand Javascript and Jquery Editor's list are given here. Sublime Text, Visual Studio Code, Brackets, Atom, Komodo Edit, Notepad++, Emacs... Quote Link to comment Share on other sites More sharing options...
riyasathe Posted March 25, 2019 Share Posted March 25, 2019 I have the same question. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
