Administrators Nathan Posted June 29, 2012 Administrators Share Posted June 29, 2012 So I'm fairly new to anything advanced with .htaccess files. I just purchased a URL shortening script and tried installing it. I followed the readme.txt perfectly. Now when I hit the site I tries to get me to download the index.php file. If I remove the .htaccess file the page loads fine, but then when you try to click any links I obviously get an error 500 due to the missing .htaccess file. So this tells me there is an issue with the rewrite code. Hopefully someone here can spot the issue The Script I purchased: Mee.La The Site I've installed it on: cbjv.net My current .htaccess file: RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule ^info/(.*) /info.php?$1 [L] RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule ^(.*) /forward.php?$1 [L] RewriteEngine On RewriteBase /music RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule ^api.php?url=(.*)$ ./u/$1 [PT,L,QSA] RewriteEngine On RewriteCond %{HTTP_HOST} !^cbjv\.net$ RewriteRule (.*) http://cbjv.net/$1 [R=301,L] AddHandler php5-script .php Quote Link to comment Share on other sites More sharing options...
LiquiLayer - Brent Posted June 29, 2012 Share Posted June 29, 2012 Try removing this. AddHandler php5-script .php Nathan 1 Quote Link to comment Share on other sites More sharing options...
Administrators Nathan Posted June 29, 2012 Author Administrators Share Posted June 29, 2012 Thanks Brent, working perfectly now. What exactly was that line doing? Quote Link to comment Share on other sites More sharing options...
LiquiLayer - Brent Posted June 29, 2012 Share Posted June 29, 2012 You bet! Since your server is already using PHP, there's no need to tell it to use PHP, which is what that line is doing. By doing so, it cancels the server out, if that makes sense. Nathan 1 Quote Link to comment Share on other sites More sharing options...
Administrators Nathan Posted June 29, 2012 Author Administrators Share Posted June 29, 2012 You bet! Since your server is already using PHP, there's no need to tell it to use PHP, which is what that line is doing. By doing so, it cancels the server out, if that makes sense. Ah, ok, makes sense. Quote Link to comment Share on other sites More sharing options...
