Administrators Nathan Posted December 9, 2013 Administrators Posted December 9, 2013 The following code I'm having some issues with. I need to echo the variable "qtycheck" to see if it's getting populated correct as I suspect that's the issue.How can I echo it out on the page to see? <script type="text/javascript"> function check() { var elements = document.getElementsByName("quantity"); var qtycheck = document.getElementById("qtycheck").value; for (var i=0; i<elements.length; i++) { var nmbr = elements[i].value; if (nmbr > <?php echo $maxqtyorder; ?>){ alert("You've selected more treats than your package allows."); return false; } else if (nmbr > qtycheck){ alert("You've selected more treats than your package allows."); return false; } } return true; } </script> Quote
Administrators Nathan Posted December 9, 2013 Author Administrators Posted December 9, 2013 Figured out by popping it into a dialog box. alert(qtycheck); The issue was the variable was not being populated, easy to see once I had it to see. Quote
