Kakashi2020 Posted March 18, 2018 Posted March 18, 2018 What are the uses of Sub-domains and how can it help your site? matthewjohn938 1 Quote
WisTex Posted March 18, 2018 Posted March 18, 2018 If you have multiple sections on your website or are using different scripts, sometimes using subdomains is a good way to separate those sections. Each section has its own unique subdomain, which makes it easier to type directly into the browser for quick access. For example, blog.example.com would take you directly to the blog. It is also used on websites that have a lot of traffic or that require a lot of disk space, where the different subdomains can be moved to different servers as needed without affecting the URLs. For example, www.example.com might be on one server, while store.example.com might be on another. matthewjohn938, Kakashi2020 and Nathan 2 1 Quote
WisTex Posted March 18, 2018 Posted March 18, 2018 It's also useful if you are using a third-party service, such as a hosting project management system, and you want to have your domain associated with your account. For example, you have your main website on a regular web hosting account at www.example.com, and your project management system is on the provider's server and you set it up so it can be accessed at projects.example.com. (I tried to edit my earlier post to add this, but it wouldn't let me.) Kakashi2020 and matthewjohn938 2 Quote
Administrators Nathan Posted March 20, 2018 Administrators Posted March 20, 2018 I don't know that it can help your site, but it definitely can keep things organized. Such as here the main website is: https://www.prodjex.com and the forums here: https://forums.prodjex.com. I also store some example code I create here: https://examples.prodjex.com and so on. My project management system I do the same way: Root Domain: https://www.prodjax.com Actual Web Application: https://app.prodjax.com My personal preference is I really like using sub-domains and prefer them over the trailing folder structure like https://prodjex.com/forums. WisTex and matthewjohn938 1 1 Quote
Kakashi2020 Posted March 21, 2018 Author Posted March 21, 2018 You can insert keywords to the URL, It promotes good User experience if you have a large and confusing site. Using Subdomain you can rank in niche markets thereby building authority. matthewjohn938 1 Quote
matthewjohn938 Posted November 21, 2018 Posted November 21, 2018 I found great discussions over here related to sub-domain and its concept. Thanks Quote
