jakejake Posted March 29, 2018 Share Posted March 29, 2018 Hey guys! im starting my journey towards being a programmer. What is the minimum requirement of a laptop should i get to start? Quote Link to comment Share on other sites More sharing options...
WisTex Posted March 30, 2018 Share Posted March 30, 2018 (edited) It depends on what software you are using and what you are programming. For example, if you are programming in PHP, the bare minimum software you would need is a text editor, an FTP program (or another way to transfer files), and a web browser. Most modern computers could handle that quite easily (assuming you are uploading to a web server). If you are using more advanced programming tools, you would need a computer that could run those tools. For example, Windows Studio 2017 would need a computer that could run windows, have a 1.8 Ghz or better processor, 2 GB or RAM (4 GB recommended), 130 GB of free hard drive space for installation files, and a video card that supports a minimum resolution of 720px. Ref: Visual Studio 2017 System Requirements Other programs will have different requirements. Also, if you are programming in a compiled language (i.e. creating computer programs) then the requirements would typically be higher. The faster your computer, the faster it will compile. The programming tools you use will often specify what the minimum requirements are. It's hard to get more specific without knowing what kind of programming you intend on doing. Edited March 30, 2018 by WisTex Nathan 1 Quote Link to comment Share on other sites More sharing options...
EfficientNinja Posted May 4, 2018 Share Posted May 4, 2018 If you are only going to use it to code, almost any laptop that is being sold today can cater to your needs. Applications used for coding, especially for starting programmers aren't really that demanding. Even a laptop or PC with an Intel i3 or lower can still do a fine job. At least 4GB RAM should be good for basic applications and other computer tasks. Quote Link to comment Share on other sites More sharing options...
Carly Swinson Posted September 7, 2018 Share Posted September 7, 2018 If you are planning to use this laptop for at least couple of years then go for i5 and 8gb ram with at least 1gb vga card. You wont need to change it soon unless you decide to join the graphic designing too. Quote Link to comment Share on other sites More sharing options...
NerdIndeed Posted December 2, 2018 Share Posted December 2, 2018 Anything that has a core 'i' processor would do. But I suggest going for an i5 or higher to avoid scalability issues in the future. If you are planning to use a Windows 10, an 8GB ram is enough I think. Quote Link to comment Share on other sites More sharing options...
