Simen Lawson Posted September 27, 2018 Posted September 27, 2018 If you are looking for a WooCommerce product options plugin then you are at a right place. In this plugin, you can offer extra options with any item of e-store. 12 types of fields available in WooCommerce product options plugin. Which are (radio button, text area, text field, file upload, drop down, checkbox, simple checkbox, multiple select, date, time etc.). This plugin helps you in creating product options but you can also adjust the price for the individual option. Customers will be charged for choosing the product options. The price of this plugin is only 29$ and comes with 100% money back guaranty. Quote
